COMPARISON: Boost Controllers
Guest
Posts: n/a
Comparison: Boost Controllers
We hit the dyno with six sophisticated electronic controllers and one cheap ball valve
By Mike Kent, Josh Jacquot, Dave Coleman
Sport Compact Car
One hundred twenty six full throttle dyno pulls. We're pretty sure Jesse Rodriguez of Diamond Star Specialties had no idea what he was getting into when he volunteered his car for our boost controller test. Amazingly, the only problem we had was paint melting off his rear bumper.
For such a seemingly simple device, boost controllers vary wildly in cost and complexity. Electronic boost controllers offer in-cabin adjustability, supposedly better boost response and advanced mapping capabilities, but some claim mechanical systems work equally well at a fraction of the cost.
In an effort to learn the real difference between $50, $250 and $750 boost controllers, we ran all the controllers we could find on Rodriguez's very angry Eclipse GS-T Spyder.
Boost Control Basics
Every modern turbocharger uses a wastegate to regulate boost. The wastegate is simply a valve that allows exhaust to bypass the turbine, limiting the energy available to drive it . When designed into the turbine housing, they're called internal wastegates, the kind found on nearly all production cars. External wastegates are located separately from the turbocharger, somewhere between the exhaust ports and turbine housing. The remote location allows the valve to be bigger and flow path smoother, resulting in better boost control and the ability to safely manage a more powerful engine.
The small hole to the left of the turbine is the internal wastegate valve. These internal wastegates are sometime called swing valves because they swing open.
The gold-colored can is the wastegate actuator. Boost pressure is this can pushes on a diaphragm to open the wastegate.
The wastegate is held shut by a spring, and as boost builds, the wastegate actuator diaphragm pushes the wastegate open against this spring. The size of the diaphragm and strength of the spring determine how much boost it takes to open the wastegate.
All the boost controllers in this test act on the pressure signal that opens the wastegate. Reducing this pressure will keep the wastegate closed, allowing more boost to build. When the desired boost setting is reached, the controller lets pressure into the diaphragm, opening the wastegate.
Electronic controllers use either stepper motors or solenoids to do this. Stepper motor assemblies vary the opening of a precision valve, similar to a water faucet. This action is accurate, though somewhat slow. Solenoids, however, operate in either a fully open or closed position, but can change this state very quickly, feeding and releasing full pressure so quickly that the pressure in the diaphragm can be accurately controlled. Dual solenoids will give an even greater degree of precision. The HKS EVC EZ, EVC IV, and GReddy PRofec A all use an identical stepper motor assembly. The GReddy PRofec B and Blitz SBC i-D share a common dual solenoid design, though they drive them differently. A'pexi stands alone with its single solenoid design.
If a wastegate is set to 10 psi, it may start to open around 6 psi, slowing the turbo's acceleration and finally reaching equilibrium at 10 psi. Boost controllers can improve turbo response by keeping pressure off the wastegate as long as possible, making more energy available to drive the turbine. Just as boost reaches the set point, pressure is dumped on the diaphragm to rapidly open the wastegate, and hopefully keep from spiking the boost.
The Testing
Testing was performed on a 1997 Eclipse GS-T with a front-mount intercooler, big injectors, cams, a popular hybrid turbo known as a Frank Stage 3, and a 3-inch exhaust. Two key points to remember when comparing these results are that this car exhibits minor boost creep and it has an internal wastegate.
We intentionally tested a car with boost creep because it's a common problem. In a later test, we'll use these same controllers with an external wastegate.
A Dynojet was used to simulate the load of accelerating on the street in third gear. Our two basic tests tracked boost when the throttle was slammed open at 2000 rpm and at 4500 rpm. The 2000-rpm test would give the controllers a chance to highlight any improvement in response, and illustrate their stability through the rev range. Tipping in from 4500 rpm challenges the controllers ability to suppress boost spiking as the turbo is already up to speed.
Interpreting the Results
When interpreting the data, don't dwell on the final boost level. We were shooting for 12 and 17 psi, but didn't spend too much effort landing right on those values. More important is the rate at which boost builds, and the controller's ability to prevent spikes and hold a constant boost level. The tests at 2000 and 4500 rpm are shown on separate charts.
The transition from building boost to holding it is a demanding event for the boost controller. The longer boost can be kept from the diaphragm, the quicker the boost will build. Wait too long and it will overshoot, open it early and response is soft. Even if you get the timing right, there's the problem of how much to open. Again, not enough and the boost keeps going up, too much and your gauge will bounce like a basketball.
Finally, remember these tests were done on a car with an internal wastegate that does exhibit boost creep. Some controllers specifically warn against use on engines like this, and not surprisingly, they didn't work so well.
How We Did It
Testing is all in the numbers, and you need lots of numbers to really understand what's going on with seven different boost controllers. For this test we used an Edelbrock QwikData. Boasting a maximum sampling rate of 500 Hz, it had no problem keeping good records of our boost controllers' performance. We used two of the eight analog inputs for TPS and boost, one of the six digital inputs for rpm. The Windows-based software allowed us to monitor all the sensor readings in real-time on screen to make sure everything looked good. Watch for a complete review as soon as we get more creative with this great tuning tool.
Edelbrock QwikData
TESTED CONTROLLERS
A'pexi AVC-R
Blitz SBC i-D
GReddy PRofec-A
GReddy PRofec-B
HKS EVC EZ
HKS EVC IV Silver Edition
Ball Valve
Sport Compact Car
The Testing
How We Did It
Edelbrock QwikData
TESTED CONTROLLERS
A'pexi AVC-R
Blitz SBC i-D
GReddy PRofec-A
GReddy PRofec-B
HKS EVC EZ
Ball Valve
Damn, I read through all that hoping to get a nice side by side graphical comparison of all the different controllers and in the end all I get is a bunch of subjective commentary from a guy who sounds like he has a hard time setting the time on his VCR.
To top it off most of the products state that they are not for use with internal wastegates and they use a test car with an internal wastegate anyways. This renders a comparative test usless.
The idea of a comparison was nice and there was some information in there on the different features of the different controllers but in the end this whole excercise was a waste of time.
Several links to the features pages for each of the manufacturers would have been as effective.
Yeah well I read it and still not sure, a friend of mine "DSM" has the Greddy PRofec-B and it seems badass. Anyone have any opinions or thought's on what they like?
TR's official early morning bass fishing crew
R.I.P.
2003 Mazda Speed Protege - Black Mica
# 886 out of 1750
1/4 Times
60 2.26 1/8 8.96 mph 82.97 1/4 13.72 mph 103.36
R.I.P.
# 886 out of 1750
1/4 Times
Guest
Posts: n/a
I can only comment on what I had and that was the Apex-i AVC-R. I have no complaints about it. It worked good and gave alot of good information to boot such as RPM, Throttle %, Speed, etc. It made it really easy to trouble shoot problems by having all those variables displayed for you. I've heard complaints about it not being easy to use, but I disagree. It did take a short time getting used to, 5-10 minutes0, but nothing that would have prevented me from buying it.
Since I have a low tech turbo I bought the HKS EVC IV after doing some research.
The Apex-i was my other top pick but between cost and functionality the HKS was my final choice.
It has all the features I want but I have yet to install it.
When the porsche comes back to life I will have more to say about it.
I have the actual issue this article came in, and it was far more in-depth than the web version. It had graphs that showed the response time of the controller and some other things. I'll try to find it, if I do, I'll take some pictures of the pages and post them.
