Sponsored by: CARiD
"The unsettled debate nitrous "
Old 10-21-2003 | 08:34 AM
  #22 (permalink)
HybridSS's Avatar
I have fuzzy eyebrows
Nitrous Oxide (N2O) does not add pressure to the intake charge. Yes it is stored in a pressurized container as a liquid. When introduced to the incoming air the pressure is equalized and the N2O boils off to it's gaseous state. This has the benefit of absorbing heat energy from the intake charge and providing a cooling and drying effect. The air in the intake charge along with the N2O which is now a gas at atmospheric pressure is then drawn into the cylinder with added fuel, not forced in
I really love the concise description Richard has made here. Especially the portion where it sais the high pressure gas exiting the nozzle is equalized with the negative vacum pressure. This happens VERY rapidly. The high pressure nitrous stream is very small in comparison the the much larger volume of ambient air already in vacum. So when the two pressures equalize...the total of the two is still in vacum. Even more so once youve been spraying a few microseconds and the VE picks up a bit creating more vacum as the HP rises.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old 10-21-2003 | 09:51 AM
  #25 (permalink)
Half Fast's Avatar
LT1's are slow!
I wouldn't give too much credit to anyone that doesn't know that the nitrous oxide molecule is N2O, instead of NO2 which is nitrogen dioxide.
Richard
1996 Corvette CE coupe LT1/A4
Mostly stock
1998 Camaro
Z28 badges and dual exhaust tips
Old 10-21-2003 | 10:22 AM
  #27 (permalink)
racingtheburg's Avatar
Pro 5oh
The nitrous has 2 solenoids, one is fuel, the other is for N2O. When you hit the nitrous button, it opens the solenoid alowing the fuel to pass through one, and the N20 to pass through the other, this mixture is then PULLED into the combustion chamber.
Old 10-21-2003 | 11:14 AM
  #28 (permalink)
HybridSS's Avatar
NMRA rules
Browse this link for the NMRAs rules on Super Street Outlaw. It has lots of refernces concerning "power adders" as well as "Forced Induction". Check the definition of power adder.
Check the descriptions for boost controller and intercoolers in refernce to Turbos and SC. They are usually refered to as forced induction. No where in there will you find Forced Induction refered towards Nitrous.
Old 10-21-2003 | 07:58 PM
  #29 (permalink)
1BFC's Avatar
lol when I post dictionary references I get bagged on....guess I need more posts under my belt before I can get away with it.
Anyway,
I think my original explanation of why Nitrous Injection (key word there..."injection") is not Forced Induction was enough for most people.
It is definitely true that the expansion of "liquid" N20 will raise the combustion chamber. That process is not however, referred to as forced induction and you must have "liquid" N20 make it all the way into the combustion chamber before that will happen. Gaseous N20 won't raise chamber pressures before the ignition event.
Personally, in the end it just doesn't matter. Use what fits your setup best. N20 is superior in virtually all aspects for power production. It's draw backs are obviously refills and safety. In a perfect world where the bottle never went dry and fuel solenoid always worked (talk about no fun when that doesn't open right..) N20 would be the hands down winner in the power adder camp.
One of the coolest things I saw years ago was a filter that allowed more Oxygen molecules through than Nitrogen. It raised the % of Oxygen present in the air stream after the filter by 5-12%. Of course the filter was the size of a locomotive at the time.....kind of hard to slap that on the end of your FIPK...
-BFC
"Life Begins at 2.0BAR"
(right click, save as)
Old 10-22-2003 | 04:04 AM
  #30 (permalink)
Half Fast's Avatar
LT1's are slow!
Richard
Mostly stock
1998 Camaro
