Sponsored by: CARiD
Turbo Civics
Old 02-13-2001 | 04:24 PM
TealTalon's Avatar
From what Ive heard alot of poorly setup ones have BAD boost creep. Sure they have an 8# spring in the wastegate but it creeps up to about 10-12 at times. I think that may be a cause for alot of failures. Man that would scare me too much. I would build the motor for boost. No rooom for error and resisting temptaion for more boost would be too scary for me.
Old 02-14-2001 | 09:30 PM
Mr 2's Avatar
New Member
Thanks I am not doing any setup of this sort I was just wondering. So a B16a can do around 8psi that must be a pretty strong motor.
Thats Mr. to you
95 Eclipse GS-T
89 MR2 NA
-Eric
Old 02-15-2001 | 01:02 AM
93ex's Avatar
Just Ledoux it!
Im lost why does a boost controller blow a motor? I figured that would let you turn it down during street stuff and then back to 8 for track but hey.
Old 02-15-2001 | 05:35 AM
emodsm's Avatar
red ass
Originally posted by "Someone"
It seems to me that the base psi setting for the wastegate on most hondas is right around 8psi a boost controler will only let you go up in psi never down.
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
Old 02-15-2001 | 06:51 AM
TealTalon's Avatar
Probably referring to resisting the temptation to turn the shiny boost knob. Once you feel an extra couple punds of boost you want it all the time.
Old 02-15-2001 | 09:57 AM
16gAWD's Avatar
BOOST CREAP!!!!!
James
Just another unreliable fast DSM
http://www27.brinkster.com/awd16g/
