i need help
100 shot
__________________________________________
www.floridasportsman.com
Originally Posted by P057
"Wow I had a hard time understanding that... but from what I gather you found an open-box item that wasn't cheaper. You bought it anyways. You then called someone a dumbass while making fun of their misfortune of losing a job as you were leaving the store?
I'm surprised you were able to get out the store with that big "SUCKER" sign affixed to your back. "
Ok, First what kind of kit are you going to get? Wet , Dry? Direct Port? This decision will affect how much Nitrous you can "safely" run. This said. If you run a wet system will you run a dedicated nitrous fuel system? This would also allow you to run more N2O. So it all really depends on what type of system you want to run / build.
You can use Nitrous without blowing it up. Really it just matters how hard you wanna push it. If you want to feel the power I would build a system around your 10 pound bottle. You can safley and affordable have a set up running 100 horse.
porsche-crazy yes you can n2o very easily. We have done many installs in all sorts of applications. I am actually putting a kit in a car today. LMK if I can help. Contact info below.
p.s. yes there are alot of d***ks on here
k its not stock wen i bot the car it was all apart and i had 2 order new every thing so i was like f**k it and started ordering performance parts so i think itl hold up atleast i hope lol but also i got the head shaved 10'000 so does nos work with more or less compreshin? if its less i need a new head
