Sponsored by: CARiD
Nitrous Guys - I Have a Question
Old 10-12-2008 | 04:21 PM
Largo 5.0's Avatar
Coming Soon
Default Nitrous Guys - I Have a Question
so i plan on purchasing nitrous for my mustang sometime after January. my question is reguarding nitrous pressure. have any of you every had a problem with the pressure being too high (without a heater) when racing, or sitting in the sun here in FL. im tossed up whether i should get the Fire & Ice heater/cooler or if i will be fine with just a heater?
Old 10-12-2008 | 06:43 PM
jriggs's Avatar
is better than you™
I've ran a 75 wet shot for a while now on different cars. If your tanks are properly filled you shouldn't have any problems with the tank pressure getting to high. I had one shop over fill my tank and the blow out disk popped while the car was in a parking lot. They fixed the safety and properly refilled the tank for free. Other than that I've never had a problem.
Old 10-12-2008 | 08:37 PM
Tiffiny's Avatar
I can fix your bullshit
yes a regular bottle heater will be fine working properly it will maintain a constant pressure that you need good luck
Old 10-13-2008 | 05:02 PM
Largo 5.0's Avatar
Coming Soon
so sitting in staging in a 98º july day, ill still be fine? wont shoot up too much? i know if its only like 100psi or so over i can purge it off. but i dont want to have to ever really worry about it.
Old 10-13-2008 | 05:36 PM
jriggs's Avatar
is better than you™
when the bottle is filled it is no where near the safety point, you really don't need to worry about it. the reason i had a problems was the guy that filled it at the shop was new and trying to play like he was one of the big boys. he way way over filled the tank.
you'll be fine
Old 10-15-2008 | 07:18 AM
dk1989's Avatar
Ill f@cking end you!
Yeah I have bottle sit in the blistering FL heat all day and never had any worries.
Ricer: From the latin word Ricarius meaning to suck at everything you attempt!
AIM = donkeyk1989
XBOX Gamertag = DK1989
Myspace.com/donkey_kong1989
DK for Mod since people care
Parris Island here I come =D!
Old 10-15-2008 | 07:52 AM
ghostofnyc's Avatar
N20 Whore
i spray any where from 1100-1200psi
F.D.L.R / Midnight Auto/ Induction Performance
RIP BOOGA
When the Green Light Drops the Bullshit Stops.
ALPHA TUNING For all of your tuning needs 813-443-5064 http://www.inductionperformance.com/
Old 10-15-2008 | 09:56 AM
nx01gt's Avatar
1100 psi is 97 degrees i belive.......
dont quote me but i know its around there
i doubt your going to have a problem. if your psi goes over 1300 just put a damp cold rag on it
either way its not going to burst unless it goes over like 1800
Old 10-16-2008 | 04:39 PM
Largo 5.0's Avatar
Coming Soon
im not so much worried about it bursting (can always remove it from a car) i just want to be sure it stays around 1000-1100 in staging so i dont have to piss away a bunch of nitrous purging it off. if it is always sitting above that i would rather invest the $350 into a heater/cooler to avoid having to loose nitrous purging the pressure down.
soundsl like i dont have anything to worry about either way though!
Old 10-16-2008 | 07:56 PM
jriggs's Avatar
is better than you™
if your tank pressure is high the regulator should cut it down to the proper psi
