Sponsored by: CARiD
Survey Dump vs Blow Off Valves
Old 02-06-2002 | 11:16 AM
SLAAB's Avatar
Yes.. here is a pic of the MAF stock airbox and intake tube
E90 6MT ZSP ZPP 322 522 LCCZ 688
E83 6AT ZSP ZPP 522 508 4AS 191M LUSW A35
Old 12-28-2007 | 08:19 AM
trevs1946's Avatar
I've recently got a Baily DV 12 dump valve for my 03 Impreza, It's running 330BHP and I'm hoping for better response thru the gears. It appears I made the right choice over the blow off valve?
Old 12-28-2007 | 08:24 AM
Colonel Mustard's Avatar
They call me Cooter..
holy 6 year old thread...
Captain Morgan: When you die and go to heaven,you'll talk to God. THIS will be the stuff you'll smell on his breath.
Old 01-03-2008 | 10:38 PM
KustomKonceptz's Avatar
They are the same thing, however bypass valve is just a BOV with a recirculation. See, the turbo sucks so much air in from the MAF, and when you release this pressure into the atmosphere, the engine doedn't end up seeing the same amount of air that your MAF saw. What this means is that when you shift you will be releasing metered air into the atmosphere, and for that time your car will run very rich.
