Any FI guru's have views on this?
Guest
Posts: n/a
From expierence, I had no problems with this setup until I went over 6.5psi. In fact it ran wonderfully.
I do however, agree, that only under very cool conditions could this A/F ratio be safe. There was no detonation to the best of my (and race related's) knowledge. Granted I had a working knock sensor, and 93 octane. It was however, a pretttty hot day.
Did some of you bother to read my entire post?
A boosting or WOT motor is under adverse conditions IMHO.
In fact I would be willing to bet that most of your factory high output n/a motors are staying in closed loop (which should by right around 14:1 a/f) to somewhere between 75% - 85% throttle.
A turbo would be doing the same up until a certain level but the same idea applies.
The point I was making is that 14:1 is not 'lean' but perfect for the conditions most cars operate at 98% of the time. I have seen no disagreement with this point yet.
I also know when lower numbers are required, but how low and when depend on the motor. So why jump down my throat?
I'm just passing along some wisdom so that some of our TR newbies don't think that you need to be running a 12:1 a/f ratio on their motors under all conditions.
The only reason to go any lower is to reduce the risk of detonation in high compression or forced induction motors.
For that reason I would say it is not lean, but just not rich enough for use under adverse conditions.
Guest
Posts: n/a
\^/07 c0|\|d1710|\|5 4|23 4dv3|253? 1 7h0ugh7 7h475 \^/hy m057 0f u5 b0ugh7 7h3 7yp3 0f c4|25 7h47 \^/3 d1d? |\|0\^/ 7h47 y0u cl4|21f13d y0u|253lf, 7h3|\| y35, 1 d0 4g|233, bu7 m0d3|2|\| 7u|2b0 c4|25 ch4|\|g3 0v3|2 70 0p3|\| l00p 4|\|d qu1ckly |2u|\| 47 7h3 l34|\|357 1'v3 533|\|, 13:1 0|\| 4 b0>< 570ck c4|2. 7h15 15 |2u|\||\|1|\|g 7h|20ugh c475 50 7h47 c0uld 3451ly b3 |21ch3|2.
0h 4|\|d m4|\|y c4|25 |\|0\^/ 4 d4y5 |2u|\| 3v3|\| l34|\|3|2 7h4|\| 14.1 u|\|d3|2 l1gh7 7h|2077l3 4|\|d c|2u153. 7h3 0ld3|2 CVCC H0|\|d4 3|\|g1|\|35 50m371m35 |24|\| 45 l34|\| 45 17-18:1 f0|2 fu3l 3ff1c13|\|cy! P|2377y 4m4z1|\|g f0|2 1977 73ch|\|0l0gy.
you know porsche guy
i'm pretty sure that you have no idea what youre talking about 100% of the time.
rest in peace tim.
rest in peace tim.
Originally posted by "Mattback"
You really need to lean that bitch down a bit.
Matt your just too stupid for words to describe you...
And everyone claims you know something, you know nothing..Ricer tool.
custom parts is our perfection.
Guest
Posts: n/a
[qu073][1]0|21g1|\|4lly p0573d by "L3v1"[/1]
[qu073="M477b4ck"][qu073="L3v1"]
Y0u |234lly |\|33d 70 l34|\| 7h47 b17ch d0\^/|\| 4 b17. [/qu073]
[1mg]h77p://65.34.70.220/1m4g35/|2374|2d3d41|2fu3l.jpg[/1mg]
:l0l:[/qu073]
M477 y0u|2 ju57 700 57up1d f0|2 \^/0|2d5 70 d35c|21b3 y0u... :l0l:
4|\|d 3v3|2y0|\|3 cl41m5 y0u k|\|0\^/ 50m37h1|\|g, y0u k|\|0\^/ |\|07h1|\|g..|21c3|2 700l.[/qu073]
\^/h37h3|2 0|2 |\|07 h3 d|21v35 4 |21c3 c4|2 m34|\|5 |\|07h1|\|g f0|2 7h3 f4c7 7h47 h3 15 100% c0|2|23c7 : 14:1 15 L34|\|, |\|07 |21ch, f0|2 4 f/1 c4|2. 4|23 y0u g01|\|g 70 4|2gu3 7h47?
:l0l:[/qu073]
