Sponsored by: CARiD
Any FI guru's have views on this?
Old 10-24-2002, 07:17 PM
Guest
0HP930's Avatar
Its a basic engineering calculation that will always prove true.
I posted the same equation months ago.
https://www.tamparacing.com/phpBB2/viewtopic.php?p=248030&highlight=#248030
Old 10-29-2002, 05:42 AM
sooo...where's the turbo?
2TurboImports's Avatar
or if you know your HP at a given RPM you can calculate torque using
Torque = HP * 5252
RPM
In Cronic Burn's Case....he gets his max torque at about 6100 RPMs...I plugged in quite a few times to get the numbers right....
156.9*5252 = 824038.8
824038.8/6100 = 135.08 that's only .42 shy of 135.5 and now you know your torque curve.
Old 10-29-2002, 08:31 AM
Levi's Avatar
Damn Jeff, that A/F ratio is horrible.
You really need to lean that bitch down a bit. try for 12 or 11s, you will make more power, and still be safe.
You will notice you made peak power right @ 12
custom parts is our perfection.
Old 10-29-2002, 09:23 AM
hmm, damn, that is weird, stoopid math equations....
Old 11-03-2002, 01:58 PM
Bob22b's Avatar
Uhhhh O
