poor man's itr ej1 coupe
Old 08-24-2009 | 04:48 PM
onebadcoupe's Avatar
Default poor man's itr ej1 coupe
havent seen anything too interesting in these threads so for so ill post my build up. i bent some valves one night and had no compression in cylinder no.4. pulled the head and decided i might as well do the rings while im going to have down time than decided i might as well raise the compression and contacted rs machine for their 81mm pr3 pistons. all assembly work was done by me on the bottom end.
1st gen b16 head
skunk2 stage 2 cams
supertech valvetrain and portflow nitride flat faced valves
new valve seals,bronze valve guides
portflow 3 angle valve job
00 gsr block
81 X 87.2
81mm pr3 piston
stock gsr rods and rod bolts
00 gsr trans
skunk2 pro series intake manifold
hytech replica header
2 1/2 in test pipe and exhaust piping exiting a magnaflow muffler
custom 3 inch cold air intake with a velocty stack routed out the front grill.
p28 chipped and socketed with a p73 rom for now afrs look good during part throttle. starts to lean out in vtec though and has a rich idle. timing is set on the street. ill fine tune it once i get on the dyno. upon driving around for a few miles i notcied heavy blue/gray smoke coming from the exhaust. upon closer inspection i discovered no.3 cylinder wrist pin failed and was protruding out of the side of the piston and dug 2 grooves into the cylinder wall. long story short domestic machine shops suck working on import parts lol. im looking for another block now to reinstall everything into onto the pics.
my brothers donor gsr that got totalled
the coupe's old set up
Old 08-24-2009 | 05:28 PM
zhillz's Avatar
Porno Music Producer
Nice, any more pice of the car? Specs?
Old 08-28-2009 | 04:41 PM
update: i picked up a LS block a few days ago. its at the machine shop now getting cleaned and hone. should be getting it back tomorrow or monday. LS block with gsr/b16 internals here i come.
Old 08-28-2009 | 07:12 PM
Paulino's Avatar
Not harsh, just truthful
Use P30 pistons instead of the PR3's if you can get your hands on them unless you are going aftermarket because i don't advise to use ctr pistons because of their compression.
Old 08-30-2009 | 12:22 AM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
its better to use the gsr block with the ls crank and pr3 pistions the girdle is the best thing you can have on a b series
JumpManPm me for any needs for a Honda/Acura/Evo. From tune ups to motor builds TR "Old Skool DA" Member #91Still Jokie!!!!!!!!!
Old 08-30-2009 | 11:07 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
ORLY
-Winston Churchill
Old 08-31-2009 | 01:28 AM
pr3's and jdm b16 pistonpct's are ctr'sas for the the set up. its gsr crank and rods in an ls not ls crank and rods. I was contemplating have the machine shop install the girdle from the gsr onto the 3 ls mains. but they're are plently of high reving non girdled lsvtec/b0vtec and b16 out there. im going to reuse the gsr block and have it sleeved and bored down the road anyway.as for my current ls block I should have it back from the machine shop tomorrow and assembly can begin. stopped at acura yesterday to order a new wrist pin. ill have that tuesday. ill post pics as things progress.
Old 08-31-2009 | 03:54 PM
Bite_Size's Avatar
עִמָּנוּ אֵל
Imo that gsr crank is gonna kill u really bad on achieving your high comp goals. Keep in mind that the LS block has a high deck height, and ur gonna be using a 87.2 mm crank in a block that originaly had an 89 mm in it. Do u still have the LS crank with that block?
Old 08-31-2009 | 04:12 PM
Bite_Size's Avatar
עִמָּנוּ אֵל
Please excuse the post above for that I had my information all wrong. The b18c1 deck height is 212.4 mm while the b18a/b has a 211.8 mm deck height. I apologize for the illinformed post.
Old 08-31-2009 | 08:00 PM
no problem, compression wise im shootin between 11.4:1-11.6:1 with a 2 layer ls head gasket.
