boost leak help?
boost leak help?
hey s&r i own 05 sti an an did a boost leak check at a local shop an the guys said that its coming from an inlet pipe from turbo and a massive one coming from the bottom of the top mount area. also my check engine is on and cruise light is flashin for the last couple of weeks?? wanting see what could be the problem and your pricing would be for this fix?
thanks,
thanks,
Turbo inlet hose is very common to crack. Funny we had an 05 sti come by today with the same problem.
Stock turbo inlet hose $114.99. If you want the Perrin hose it is $229 and they are out of stock.
Intake gaskets 2 x $5.58
3.0 hours to do the job. $270 Takes all of the 3 hours too.
Call us anytime (813) 961-0609
the 05 sti was me brad.....i ordered the wide band so it should be comin in withing the next few days and will be comin in friday after work to drop the car off ... also im not sure if you guys put me in scott siegels list for the tune?
thanks SnR.
thanks SnR.
