Fully Built Block, CTR head, AEM EMS, 1000cc injectors, ACT clutch, etc
Old 10-18-2007 | 10:24 PM
JDM.Squeek's Avatar
Default Fully Built Block, CTR head, AEM EMS, 1000cc injectors, ACT clutch, etc
Fully Built LS Block
B18B1 Block
AEBS T-Sleeves 86mm
JE Pistons 9.1:1
Total Seal Piston Rings
Eagle H-Beam Rods
VTEC Oil Pick up
VTEC Oil Baffle
VTEC Oil Pump (Type -R)
VTEC Water pump
VTEC Dowel Pins
Brand New Honda Timing Belt
Golden Eagle Head Studs
Everything installed professionally, all clearances checked, Engine balanced, comes with all normal parts like the oil pan, tensioner, pretty much ready to go.
PRICE $2,000
PR3-3 EK9 Civic Type-R Head
Head comes COMPLETE:
Mild Intake Port
Port Matched CTR intake manifold
Throttle body
CTR Camshafts, cam gears
everything else is stock (CTR)
All sensors on head and intake manifold including map, and TPS on throttle body
Intake Manifold Spacer (up to 30 degrees cooler, In. Temp)
High Volume Fuel Rail w/ Guage
NO INJECTORS Look down on the list!!
PRICE $900 O.B.O
SOMEBODY SENDS ME A SERIOUS OFFER I WILL TAKE THE HEAD OFF AND TAKE PICS OFF THE HEAD AND INTERNALS OF THE BLOCK!!! SEND ME PM IF INTERESTED IN ENTIRE LONG BLOCK!!!
Pics
AEM EMS OBDI Honda/Acura (1040)
Price: $800
GSR Hydraulic Tranny
No grinds and goes into every gear smoothly
Includes NEW starter
Price $400 o.b.o.
Turbo Manifold and Waste Gate (as seen in pics)
-XS Power Race Top mount Turbo Manifold T4 Flange
-XS Power 60mm Wastegate (V-Band also, refer to pics)
LOWERED PRICE: $250 o.b.o.
Pics
more pics up later
Siemens 1000cc Injectors (Flow tested!)
Lowered Price $200
Pics
ACT Heavy Duty Pressure Plate and 6-Puck Unsprung Disc
Good for 420ft/lbs Tq.
Price: $200....$340 NEW
Fidanza 11lb Flywheel
Price $80.......$150 NEW
Pics
OBDI VTEC Distributor w/MSD SS Coil w/Wire
Price $120
Aeromotive A1000 Fuel Pump
Price: $200 ($325 new and this one it barely used)
B-series axles (BOTH, Great condition)
Price $80 for both
Old 10-18-2007 | 11:20 PM
MoneyMike941's Avatar
Eat a Dick
R.I.P Dad.
6/23/40 - 1/12/08 7:50pm
**kids in the back seats cause accidents and accidents in the back seats cause kids, stick with a 2seater**
2012 = New Y2K
