FS: misc. honda and acura parts.
Old 10-28-2009 | 08:34 AM
tomanyprojects's Avatar
Default FS: misc. honda and acura parts.
Trying to clean out the garage. I have a lot of stuff.
All parts are also best offer too.
S2000:
03 front sway bar with bushings $40
oem brake rotors still in excellent shape $40
civic
06 and up oem 15inch five lug steel wheels with hub caps $50
b-series knock sensor $40
d-series throttle body $25
4 b-series throttles $25
5 alternators b-series and d-series all work $40 each
oem d16 flywheel $20
black eg center console pieces $20 each or $30 for both
LS b18a bare block in excellent condition, comes with crank still bolted in. $100
95 civic si tranny no grinds good condition $200
integra
p73 type-r pistons $75
automatic integra gauge cluster $40
black dash with airbag $75
red rs oem wing $35
black driver door: no glass, no dents. Does have interior panel $30
GSR rear disc conversion everything you need to bolt it right up. Caliper, rotor, full trailing arm everything $300
GSR front brake conversion everything you need to bolt it on. Caliper, rotor, entire hub assembly $200
new ls water pump $20
2 b-series headers $40 each
92-93 P61 gsr intake manifold w/tb $60
2 B16 intake manifolds $40 each
obd2 LS intake manifold $40
2 obd0 LS intake manifolds $40 each
oem LS flywheel $25
JDM B16 flywheel $35
both black interior rear quarter panels $60
oem LS wing dark green $40
oem LS cams $30
95 both rear taillights $80
2000 CRV
engine mounts $50
ecu $60
new fuel pump $40
SRT-4
03 and 05 oem computers $75 each
Misc.
brand new PCT civic type-r pistons with pins and rings. $150
4 hoosier A6 competition tires 225/40-18 good tread still left on them. $350
vortech 12:1 rising rate fuel regulater $30
black crx or EF civic cluster cover $40
D-series and B-series parts:
engine mounts, a/c brackets, power steering brackets, oil pans, oil pickups, water pumps, crank pulleys $20 each ASk me for specifics i prob. have it.
cast iron turbo manifold for a t3/t4 turbo with a 38mm wastegate flange $125
used direct port nitrous kit. includes 10lb bottle, upgraded solinoids, all fittngs and lines needed to hook it up. $350
prices negotiable
call me or text me anytime 813-500-1760 ask for pete
since there is so many items if you want any pics i can either text them to you or email them at your request
Old 02-21-2010 | 04:44 PM
k-boy's Avatar
hey u still sealling the d series throttle body?
