Subaru Tech All We'll Drive
Check your oil pick up tube
Old 07-17-2009 | 06:06 PM
SteelDragonSTi's Avatar
The slowest STi in the US
Default Check your oil pick up tube
I'm sure some of you already know this, but as a reminder... check your oil pick up tube. Its a small investment to protect your engine.
Its apparent the oil pick up tube fails on the EJ25 motor at 30 to 40k miles. I just replaced mine and it was cracked half way around the tube where the flange connects to the block. There is a trend of this failure on IWSTI and NASIOC.
Just a PSA.
Oil pick up tube broken... - IWSTI.com: Subaru WRX STI Forums
Official oil pickup tube failure thread - NASIOC
2006 Subaru CGM STi
Powered by My Retirement Funds
Old 07-18-2009 | 05:34 AM
specVmatt's Avatar
400hp club, barely
How long did the process take you?
Coyote
Old 07-18-2009 | 01:57 PM
cheesetits's Avatar
+1
Old 07-18-2009 | 06:29 PM
It was about 3 hours of labor total. Could be done in less.
I need to rebuild the engine again. I'm looking for another alternative to the OEM pick up line. Cant afford to loose another build.
2006 Subaru CGM STi
Old 07-18-2009 | 06:32 PM
im2wrxy's Avatar
Import Image Racing: Cosworth Subaru EJ20 & EJ25 High Volume Oil Pan
Old 07-18-2009 | 06:56 PM
chome's Avatar
Will sleep for food.
What approach did you take in order to remove the oil pan? Did you pull the motor a bit or just raise it on the mounts?
Old 07-18-2009 | 07:43 PM
blacksti's Avatar
DudeMan
you can drop the oil pan with out raising or removing the motor...
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old 07-18-2009 | 07:56 PM
chome's Avatar
Good to know. On a thread I read last night the guy unbolted the radiator and raised the motor a tad bit so I figured it wouldnt clear the subframe with the motor unraised.
Old 07-19-2009 | 10:49 AM
blacksti's Avatar
DudeMan
nah you can just drop it. the kid who got my sti put in a new motor then it spun a bearing so he dropped the oil pan and switched two bearings then traded it in the next day lol
btw if anyone see my old sti try and get his info im gonna try and get it back
2jz mustang build
Old 08-07-2009 | 08:56 AM
djerickd's Avatar
CHILLING SPREE!!!
Killer B makes a replacement that is more rugged:
http://www.killerbmotorsport.com/ind...dOilPickup.htm
and the most ultimate oil pickup ever!
http://www.killerbmotorsport.com/ind...teOiPickup.htm
more:
Oil Pickup Story - Subaru Oil Pickup Failure
SnowMan Tuned
