Subaru Tech All We'll Drive
400+HP 1990 Subaru Legacy wagon ?
Old 12-01-2009, 09:10 PM
yeah, I drive a miata
LDadrenaline's Avatar
If you are looking for a shop to do the swap/build, go to S&R. Mike over there has/had arguably one of the most modified legacy wagons in the country....
[/center]
Old 12-01-2009, 10:19 PM
fitbikeco's Avatar
nothing like spending over 10k for a old car that runs high 11s
Old 12-02-2009, 03:38 AM
High Altitude Performance
treveym's Avatar
i know its not a legacy, but worth the look for inspiration...
Top Scoob: It's All STi on the Inside .. Top Scoob 016
Old 12-02-2009, 03:49 AM
eats gunpowder
mranlet's Avatar
Do you already have the chassis? Have you looked into starting with a Legacy RS (EJ22T block, factory turbo, etc)? Is this an endeavor you're looking to perform yourself or would you be bringing it to someone who has more experience and fabrication capabilities?
If you're dead set doing a swap, the main items you'd want to focus on are:
EJ257 block, recommend CP pistons and Carillo rods built by a professional
Turbo front crossmember
Rotated Turbo, whether it be a modified Perrin, Ultimate Racing or custom made with front mount intercooler
Walbro 255 fuel pump
STI 6-speed conversion with R180 rear end
Fuel injectors
Wiring service (probably not something you would want to engage in unless you have a lot of wiring experience)
Although the hard points for things like the front and rear subframes are largely the same from 89-present, there are quite a few sheetmetal differences that will prohibit you from using an off the shelf downpipe, FMIC setup or even TMIC.
BTTS, STFU&D
Old 12-02-2009, 04:42 AM
Project Flying Dutchman
s2k<3er's Avatar
a forester would be bad ass. but i would like to see this thing with an awd 400+hp set up.
Old 12-02-2009, 04:44 AM
s2k<3er's Avatar
thanks so much tr.
all of these are great hints and clues.
and i've heard of s&r. sounds good. and im ready for the 11k. i would love an sti. im just not looking forward to payments. so im just wanting to build this. and save up money after it's done and get an sti or an s2k. most likely an s2k since its rwd and the wagon will be awd with plenty of damn power. lol
Old 12-02-2009, 04:46 AM
  #17 (permalink)
s2k<3er's Avatar
and yes i do have the chasis. it has the stock motor put into it now. and it is my dd.
Old 12-02-2009, 04:50 AM
  #18 (permalink)
Only Bolt ons!!
Tupass's Avatar
I have a ej205 out of a 04wrx,Is almost new under 10k on it.$400 is yours,oil pump,water pump comes with it.
TampaBayTunedInc.
Area51Tuned
Old 12-02-2009, 07:33 AM
  #19 (permalink)
I'm Slow
I'm Slow's Avatar
I'll have a running sti block with all the goods available soon. $800 obo
Old 12-02-2009, 07:48 AM
  #20 (permalink)
Shake n bake
ShockerGT's Avatar
Don't forget to get a wideband
