90-93 gt,gts,st,stx celica 3sgte swap help
Old 03-14-2007 | 02:25 PM
3tc power's Avatar
Question 90-93 gt,gts,st,stx celica 3sgte swap help
ok guy i'm posting this to find out if anyone here in tampa ever done this swap on the 90-93 st184 celicas. i have a 91 gt that i'm thinking about using for the swap and i need some pointers that i can use to make this swap a little easier on me. anything can help guys....Thanks alot for your time
Rudo
Old 03-15-2007 | 01:03 PM
christo4_99's Avatar
i have the wiring harness you need for $250
the way i see it,if you combine two words,like bull and shit...well,you know the rest
Old 03-16-2007 | 11:56 AM
3tc power's Avatar
do you have anything else i can use?
Old 03-17-2007 | 09:29 AM
HellofaPrzeFghtr's Avatar
The One and Only
jdm market has 3sgtes in stock i seen em
Old 03-19-2007 | 12:54 PM
GT4SOM's Avatar
Feel teh rally bishes!
Don't get ripped by them. Just go with jarco and get yourself a nice little clip. Get your self a clip. Get yourself a clip.Get yourself a clip.Get yourself a clip.Get yourself a clip.Get yourself a clip.Get yourself a clip.Get yourself a clip.
I don't think I stressed it enough. Don't buy any engine sets with ecu harness etc... because I've seen nightmares where harnesses are cut and missing sensors. You'd spend months trying to locate some. What part of town are you located?
oh yeah btw Get yourself a clip.
1992 GTS 3sgte from hell! // 1990 GT liftback Stock 3sgte
Old 03-20-2007 | 08:47 AM
2kSnakeater's Avatar
Pastafarian FOR LIFE!!!!!
Get the GT4 clip, try to get the 92+ GT4. The 92+ has the post-revision engine with some fixes from the 90-91 year.
And instead of throwing away the awd tranny like most people do Il give you $10 for it and pick it up
sig under construction
Old 03-20-2007 | 08:50 AM
I think Ricksta still has a converted MR2 tranny for a swap, its not the best tranny in the world but you can get it for cheap from him. I also have a 92 MR2 Tranny in unkown condition. Il give you my tranny for your awd tranny. and maybe you can do something with it.
Old 03-24-2007 | 11:05 PM
hachibill's Avatar
yea sweet lemonade
basically listen to these guys. getting a clip will be the easiest way to get everything you need and not spend time searching for missing shit. the 3s will bolt up to your chassis and to your stock 5sfe tranny just fine, but that tranny isn't the strongest in the world. the stock all trac harness will have to be redone for lhd. but everything else should be pretty strait forward.
Old 03-27-2007 | 10:12 AM
3tc power's Avatar
i am going stroker... its easier and cheaper in my case. thanks for the help guys.
