MK3 Supra / 1uzfe / Single Turbo Build Thread
Won't fake the funk.
on
Its been awhile - Super busy... but stuff it starting to come together.
I got my -12an fitting welded to my oil pan, resealed that. A new-to-me 89+ subframe + poly mounts was installed. Feramic 6 puck solid disk + 2100lbs pressure plate on a steel flywheel was put on. I heat wrapped the manifolds (this sucks since it never wants to lay flat on a non flat surface) but I did my best. Still need to get SS ties for the driver side. Buttoned the W58 up (for the time being while my R154 gets built). Welded a 3.5" (from 4") vband onto the turbo and chamfered the leading edge to the flange. This gives me more room to work with. Using 94-95 Camry COPs with Bosch 211 controllers for the MS3x... Just awaiting some exhaust nuts and I can test fit the real engine in... should be no issue (except maybe the steering linkage... but we shall see).
Enjoy the slew of pictures... no particular order...
MK3 Supra - 1uzfe, Quantum Manual Swap, HX52 Billet Comp, Enkei NT03+M, JIC Reclineables... etc...
Golf TDI Diesel - 45+mpg's
on
Almost no effort to put the engine in... that was a great feeling!
I wanted to test fit and get everything good in the car before I paint the engine bay. Last thing I want to do is weld all holes shut and need to drill new ones.. or have to hammer the firewall or something... Enjoy for now... more to come
YES! lookin' great, matt.
TURBO YOUR AE86 :]... or, whatever.
https://www.tamparacing.com/forums/n...-t-25-etc.html
AE86 mishimoto aluminum radiator
https://www.tamparacing.com/forums/t...ml#post8667139
on
Alright here we go. Ordered 325ft of wire to start on the engine harness...
And I also got a crazy bulk deal on 12an and 10an fittings.... So I started to lay those out...
I ordered connectors for my RX7 injectors... going to buy some rebuild kits and do the rebuild and cleaning on my own... cause thats how I effin role.
Enj0i.
Enj0i.
on
Okay well here is another update. Not too much went on... Learned some stuff.
I rebuilt my injectors (well I still need 2 more to buy) with Mr. Injector parts. I cleaned them out, back flushed it etc... cost me $50 instead of $160. Good alternative IMO.
I bought new injector connectors and coil connectors. (nothing worse than broke ass connectors)
Found that Garret parts bolt on to the HX52. Also I found an "elongated hole" T4 gasket that fits my T4i bolt pattern. Super lucky since I cannot find the gasket for this turbo.
The rest or misc photos of the wiring.
