MK3 Supra / 1uzfe / Single Turbo Build Thread
Won't fake the funk.
on
Small little update. I got some 10an nylon hose for my oil stuff. I chose this because its a lot more flexible, easier to put together, and wont destroy my hands with frayed ends. Plus it was on sale
Also in other news, I have a new rack coming my way and some Brembo rear brakes
MK3 Supra - 1uzfe, Quantum Manual Swap, HX52 Billet Comp, Enkei NT03+M, JIC Reclineables... etc...
Golf TDI Diesel - 45+mpg's
on
Well I got a steal on a new rack
A summit order came in with 4an, 8an, 12an nylon braided hose, some random fittings and a free 5 hour energy...
Made some lines, one for the cooler is half done
Turbo oil feed, went through the frame rail and I need to add fire sleeving near the turbo for it.
Oil thermostat will probably end up around here.
Brembo Rear calipers, rotors are on the way. Need to get them repowder coated.
Current 3/5/12
Current 3/5/12
on
Alright well sorry for the long pause between updates. The last month or two of school has gotten really busy and I kept changing my mind with stuff on the Supra... but for now this is what is happening.
Brembo 2 pots for the rears
Wilwood 4 pots for the front ( I am in the middle of making a hybrid of all the kits out there and using Cobra 13" rotors instead of modified C4 Vette rotor like one of the kits do)
Modified the cross beam to allow the radiator to lean forward. I needed extra clearance on for the turbo stuff and I figure if I modify the hood right, it will promote better cooling.
Lots of wiring has been happening. I loomed most of it, but I forsee stuff changing eventually.
MS3X is done, firmware flashed, and reads from the laptop.
Made a mounting surface from 6061 to hold injector 50w resistors and ignition modules (for 2 wire COP).
Made one for the MS3x and PLX Wideband
PLX Gauge mounted in the cig lighter hole
Will be adjusting my alternator for tension with this setup.
Oil cooler is mocked up with zipties until I build brackets. The oil system is completed however.
Got a free 89+ bumper and nose piece.
Stayed Tuned!
Stayed Tuned!
on
Good to hear. How did you wind up mounting it? I made a to make a bracket because there was no way of mounting it at all.
on
Its sad to look at the dates when I last posted. As always we all get busy and that is the story here. Been working on the wiring and I keep getting discouraged because I was not satisfied with all the stock junk laying around. So I ordered a whole body rewire kit (common for hot rods) and I gutted all the wiring out of the Supra.
For the engine
Whole lot of WTF!
Interior dash wiring. I left the wires that travel to the rear of the car for now... oh and the door wiring. The rest of the wires on the driver seat are for headlight retractors, power mirrors, wipers, etc... all the needed stuff.
Enjoy! I promise I am back in action to work on this thing.
For the engine
Whole lot of WTF!
on
Quick update before work. I know I have updated in months.. Sorry
Gas Tank Removed...
Sump - SS 304 - Why? cause E85. Two 1/2 NPT Bungs and I relined it with POR15
Cam Sensor Housing machined for a clean look...
Wiring and more wiring. I removed ALL stock wiring. I kept only the stock switches and functions and everything works so far.. Windows, retraction for headlights, etc... Obviously this needs to be finished... but I didnt want to clean it up with everything not working yet.
MS3x functions
A very pathetic pop and burble on starter fluid to see if the ignition works...
1uzfe Turbo Supra First Start on MS3x - YouTube
Candid shot a friend took...
and for when I get my wheels mounted.. 285F 295 R
Gas Tank Removed...
MS3x functions
