MK3 Supra / 1uzfe / Single Turbo Build Thread
Old 02-07-2011, 08:36 AM
  #51 (permalink)
Are YOU in the ACT?
CheesePhantom's Avatar
This is getting increasingly interesting.
Bold Performance
Old 02-25-2011, 06:35 PM
  #52 (permalink)
DrLoveCoins
Jared Clarke's Avatar
suscribed. i am curious as to see how this turns out.
Old 03-21-2011, 05:14 PM
  #53 (permalink)
Won't fake the funk.
RedPhoenix's Avatar
Okay you would think more has progressed over the last month... but you would be wrong. Been working on getting the SC in shape (bushings, sway bars, and countless issues)... And then its been a downward spiral on the Supra as well....
I started on the passenger side manifold and after almost completing it, It would have never cleared a 4" downpipe, so I scrapped it and will be redoing it to look like the driver side to give me more clearance....
My girlfriend bought me front/rear bushings for the Supra, so she helped me get the front ones in (truly a keeper ). So then I started to work on the rears. However lucky for me almost everything was seized... even down to the handbrake cables to the bracket that holds to the the handle... The rear rotors were falling apart in the vents, rust pitting was so bad I could pick it all apart with a screw driver. This was really dangerous. So then I decided to drop the rear subframe for the sake of it all.
Once I got the subframe out, I found out I was missing 2/6 bolts that hold the diff to the subframe... axle to diff nuts were missing... all 4 concentric bolts were seized, toe rod had so much rust on the threads that the nut would come off without spinning the ball joint, plastic sway bar end links were rusted in the allen key area, all 6 diff bushings were seized to the sub frame worse than I have ever seen. It really seems like this was not the original subframe since there is no rust on this entire car except here....
Oh but I did get lucky... it was not cracked like a lot of pre 89 ones are. So after a liberal amount of fire/heat/swearing/hammering/cutting I have the subframe free of all the bullshit attached. Now looking at it, I will be bracing/reinforcing the subframe after I get it blasted free of surface rust and i will be making custom LCA, TRACTION, and TOE arms that use the energy suspension bushings and I have a set of solid bushings for the subframe that will be going in....
Sorry for the novel, but its been a long month.
Pics are good though.
MK3 Supra - 1uzfe, Quantum Manual Swap, HX52 Billet Comp, Enkei NT03+M, JIC Reclineables... etc...
Golf TDI Diesel - 45+mpg's
Old 03-23-2011, 09:11 PM
  #54 (permalink)
RedPhoenix's Avatar
Started on the passenger side manifold again.... Made some progress, so now it feels like the car has progressed forward! YES!
It clears the motor mount barely and it should allow me to notched the frame for the 4" DP. Sweet.
Old 03-24-2011, 08:19 PM
  #55 (permalink)
RedPhoenix's Avatar
So I finished (hopefully) the passenger side. I have it incorporating the T4 flange on it (not welded yet). Plenty of good spots to add bracing to support the turbo. Hopefully it will be fully welded soon .
Old 04-05-2011, 12:04 PM
  #56 (permalink)
koa31's Avatar
Quantum Turbo Supra coming along nicely.... Can't wait to see this machine in action.
Old 04-06-2011, 11:54 PM
  #57 (permalink)
Never Follow!
PROTOTYPE's Avatar
Really interesting build. Keep the updates coming!
"It's not about the make or model of a vehicle, IT'S HOW YOU BUILD IT!"
-Me
2004 Tupperware Mobile- DD Duty
1987 Toyota Supra- Hardtop and a swap. (In Progress)
2007 Suzuki Hayabusa- Gone but not forgot.
Old 04-13-2011, 06:29 AM
  #58 (permalink)
RedPhoenix's Avatar
Alright so I test fit the engine with the modified frame rails... besides needing to modify the engine mounts again, it all fits... So I started to do the welding. May not look like a lot... but trust me... it was no such thing.
Old 04-13-2011, 05:35 PM
  #59 (permalink)
RedPhoenix's Avatar
Okay, this was a whole lot of WTF... but the front subframe started to seperate? lol no idea, but when you bang the subframe again, the 2 stamped steel pieces move between each other, so I clamped them back together and welded them together... I guess I will do more on the subframe to strengthen it, but for now...
Old 04-16-2011, 11:57 PM
  #60 (permalink)
Never Follow!
PROTOTYPE's Avatar
Grabbed a few thing's with OB the other day and didnt see you there. Wanted to see the progress. Looking good besides the separation. Cant wait to see this thing running. I hope Orin and I can get "mine" up to my place so I can start tearing into it.
-Me
