Diverter Valve Question
A friend of mine just got a 98 Audi A4 1.8T ...Im not an audi or vw guy so i do not know how to install a diverter valve. does someone have a write up or just tell me how to do this. its probably pretty simple but i dont want to jack up anything.
thanks in advance
-Darrell
P.S. please dont make me feel too stupid
thanks in advance
-Darrell
Normally I would say VWFixx.com but the site is down try http://www.vwvortex.com/ lots of good info there
It's almost as easy as hooking up a BlowOff Valve.
There are 3 hoses that will be hooked up to a Diverter Valve.
One small 1/4" Vacuum hose that mounts to the top of the valve.
One 1/2" hose that comes off of the stock Intake pipe after the Turbo but before the T/B, It mounts to the Bottom of the Valve
AND
One 1/2" Hose that goes to the Air Intake pipe...right past the filter, Mounts to the side of the Diverter Valve.
And your done....Piece of cake....Right?
AND
Guest
Posts: n/a
AND
AND
And if you get a Forge 007 valve, they are direct fit replacements. Basically if you can find the valve, it will be self explanatory.
